Shifter is stiff - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2005, 06:02 PM   #1 (permalink)
View 98cincycamry's Photo Gallery
USA Shifter is stiff
I have a 98 Camry LE with automatic trans. When I shift from any gear to any other gear, it is quite stiff, as if the cable were kinked. Before I check it out, does anyone have any ideas? Thanks for any help here.
98cincycamry is offline   Reply With Quote
Old 09-06-2005, 07:43 PM   #2 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
check fluid
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 09-06-2005, 08:10 PM   #3 (permalink)
Gameroom cash: $369176
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
As he said, you may need to add Automatic Transmission Fluid aka the ATF
RichieRichJP is offline   Reply With Quote
Old 09-06-2005, 08:17 PM   #4 (permalink)
View 89molavi's Photo Gallery
I think your cable might need adjustment. No harm in checking the ATF; you should that regularly anyways, but I don't think that is the cause.
89molavi is offline   Reply With Quote
Old 09-11-2005, 12:52 AM   #5 (permalink)
View XKWISIT1's Photo Gallery
The problem is not the cable. The problem is the shift pin located on the neutral safety switch. They rust up preventing them from rotating. Toyota has modified the pin to a stainless steel type to prevent this problem. The part is under $20.00 Canadian. Replace this pin and you'll be fine. I replace about two a week at the dealership I work for.
XKWISIT1 is offline   Reply With Quote
