99 Camry Intermittent Brake Warning Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-06-2005, 06:33 PM   #1 (permalink)
View wpfloor's Photo Gallery
I have a 99 Camry LE 4. I had the brakes replaced not too very long ago (probably 15-20K). This past week, the brake warning light comes on for no apparent reason, then goes off. It never stays on more than 30 seconds, may do it a few times, then goes off and stays off. I live in Colorado, and as weird as this may sound, it seems to happen only when I'm climbing a steep hill or steep mountain pass. The emergency brake is full down, and the brake fluid is at normal level. I have always kind of freaked out when warning lights come on that have to do with something other than a burned out light or low windshield washer fluid. Should I be worried? Do I need to take the car in? Thanks in advance for suggestions ...
wpfloor is offline   Reply With Quote
Old 09-06-2005, 06:35 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
when you go up hill the fluid flows the the back and the float switch in the in the front. just add a little more fluid and you should be good.
^ and leaving it that way!
Old 09-06-2005, 09:33 PM   #3 (permalink)
View lenjack's Photo Gallery
The brake fluid level can be very deceiving. Top off the reservoir and the problem will go away.
lenjack is offline   Reply With Quote
Old 09-06-2005, 10:10 PM   #4 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
Just get it checked by the dealer. IMO i belive that the swich that tells if there not enough fluid in there is bad.
V6LE_CAMRY is offline   Reply With Quote
Old 09-07-2005, 12:57 AM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
you probably only need another finger or so more....but that much will make your light go on
HaHa
Old 09-07-2005, 08:59 AM   #6 (permalink)
Thanks, everyone ... if topping off the fluid doesn't do the trick, I'll report back.
Old 09-08-2005, 01:27 PM   #7 (permalink)
Down (and I mean, DOWN ) with the flu, so will be a few more days before I can report back to y'all ...
Old 09-08-2005, 01:55 PM   #8 (permalink)
The Other White Meat
terrastrife's Avatar
just ignoreit for now, you KNOW you have enough fluid :P
mines coming on more and more often as im on the last stretch of these brake pads :P
terrastrife is offline   Reply With Quote
Old 09-22-2005, 08:21 PM   #9 (permalink)
Finally getting back to you all. Put in about a finger's worth of brake fluid and the light has stayed off since. Thanks!
