Originally Posted by Mr. Cool
1. How can I get the remainings of the bolt back out.
Is there enough of the bolt sticking out that you can grab it with a pair of pliers?
If not you have a few options:
1. Drill it out, but you'll most likely mess up the threads.
2. Use a ez-out.
3. Cut a slot in the bolt, use a flathead screwdriver, and try to twist it out.
2. stabilizer end links: the part where you put the allen key in is stripped and I can't hold
the joint still so I can take the bolt off. Is there another way of getting the bolt off?
A air impact wrench will zip those nuts right off.
Otherwise use a pair of vise grips. You'll see a a rubber boot, pull the boot back and put the vise grips over the metal part. Then use a wrench on the nut.
