depends on what kind of noise, but most likely it is the regulator. I cant remember if the Gen 4 uses a cable system or if it is a gear setup. You can take the door panel off and run the winddow up and down to see if you can locate the source of the noise. If it is the regulator and it is cadle driven you will have to replace the entire assembly if it is gear driven you should be able to replace jsut the regulator I think.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
