camber kit - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-09-2005, 02:59 AM   #1 (permalink)
im hungry
View aGen5camry's Photo Gallery
camber kit
does anyone know what company's make camber kits for a gen5 camry or 04 camry..
bagged
aGen5camry is offline   Reply With Quote
Old 09-09-2005, 07:19 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
dont need it, your chassis will be scraping the ground b4 you dont have enough adjustment for 0 degree camber.
terrastrife is offline   Reply With Quote
Old 09-09-2005, 08:36 AM   #3 (permalink)
MDT
View Maxemily's Photo Gallery
Not sure what point terrastrife is making, but 0 camber is not a diffficult task. As a matter of fact 0 camber is within factory spec.
The adjustment is done on an alignment rack by loosening the strut to knuckle bolts and changing the angle of the two parts. If there is not enough play with the stock bolts your local Toyota dealer has, or can order bolts with smaller diameter shafts made specificaly for this purpose. I do not know if aftermarket suppliers have the bolts... been with Toyota far too long.
Maxemily is offline   Reply With Quote
Old 09-09-2005, 10:09 AM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
eracingworks.com has a set of camber bolts for an 87-91 Camry on auction at e-bay http://cgi.ebay.com/ebaymotors/OBX-8...QQcmdZViewItem
While these aren't the ones you're asking about the seller may be able to help you find a kit for your model.
Kep
Old 09-09-2005, 06:48 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
http://www.ingallseng.com/cars/toyota.html
"Skoolin' the unlearned!"
