Help Please!! Mechanics. . .
For those who are aadept at diagnosing problems....
For the last few months
only every few weeks typically
has happened mostly when engine is warm or hot, once when cold
I will crank the engine, it turns over, then stalls
while I try this over and over again
only occasionally it cranks and does not turn over
every time this has happened I sit there for 10-15 minutes before it actually catches and idles
No other hints of operating problems once the problem passes
This is a tough one I know-
I have installed a plasma booster and walbro 190. This sounds like a fuel issue. Probably not spark or else it would not turn over. I am thinking either the walbro is on the frits or the fuel pressure regulator is on it's way out. I have told maybe vapor lock. I released pressure from the gas cap. I have about 1/4 tank. ANY THOUGHTS???? Thanks everyone.
Was that a Camry?
