Diffence between 3sfe and 3sgte - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2005, 06:26 PM   #1 (permalink)
View The Black Camry's Photo Gallery
I want To Buy Parts For my 3sfe but i want to know what is the difference between the 3sfe and 3sgte ? And can parts be swapped from the two ?
The Black Camry is offline   Reply With Quote
Old 09-11-2005, 06:53 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Internals. 3S-GTE has forged internals.
Block. IIRC 3S-GTE has oil squirters.
Cylinder head. 3S-GTE has bigger ports, wider valve angle (45 vs. 22), and its true DOHC.
3S-GTE is also turbocharged and the 3S-FE is N/A.
Compression ratio on 3S-GTE is lower. I believe its 8.5:1. 3S-FE is 9.3:1.
Parts are swapable, but it depends which parts you want to swap.
By the way cross and/or double posting is not allowed.
how parts for my 3sfe
"Skoolin' the unlearned!"
Old 09-11-2005, 11:09 PM   #3 (permalink)
Thanks. And i Didn't See That one.
