2nd gen engine and trans swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-12-2005, 11:00 AM   #1 (permalink)
View birddog1148's Photo Gallery
Ok from what I have seen on here celica motors and trannys will swap into a camery. I run dirt track and am trying to decide if I should just build a new celica or swap motor and tranny on my camery. The camery has the 3sfe engine and an auto trans. I deffinatly want to go with a manual trans and the car will never get out of 3rd gear. will the wireing harness work with modification or should I just pull the one from the donar car? I know I will have to change ECU's Which trans are better (aka lower gear ratios) one from a camery or a celica? I plan on reinforcing my unibody and removing excess sheet metal where I can. Are there any celicas or camerys that have LSD trans or not? Thanks in advance for any help
Birddog
racing is a disease not an addiction
birddog1148 is offline   Reply With Quote
Old 09-12-2005, 12:13 PM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
Get the complete harness, makes things much easier.
You need the ECU too.
The celica and the camry share the same transmissions, so what ever manual transmission you find will be the same. None of them had an LSD, unless you find a E153 from a 3SGTE Mr2, but that will take more work to install i beleive, and im not positive all of them had one.
other than that, sounds like a fun project. There are a few 3SGE camry's running around.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 09-12-2005, 01:07 PM   #3 (permalink)
thanks
Tommy, Thanks for your response, guess I just find a motor and tranny and pull em together, gotta keep it stock appearing to pass inspection, cant have custom mounts.
Old 09-12-2005, 01:13 PM   #4 (permalink)
Tommy's Avatar
the celica engine and transmission will bolt directly in there, so unless they know what a 3SFE looks like vs a 3SGE, youll be fine.
Itd be easier for you if you could find a 5SPD camry to harvest the tranny parts from, cause youll need a lot of stuff for a conversion.
My garage
