Something weird with my suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2005, 05:21 PM   #1 (permalink)
drunken member
CCCP's Avatar
View CCCP's Photo Gallery
4th Generation Something weird with my suspension
Ok car was fine for 5k since i bought it, rite now it has 146,000km, but it developed some strange problem. Everytime i go over bumps or potholes at higher speeds, there is this rubbing sound comes from the back, like a plastic rubs on the pavement or tire rubs against body.
I had the car on the lift and found nothing hanging, or loose plastic guards under fenders,
everything looks perfect.
Any suggestions on this problem, could it be suspension related?
Thnx for any help ppl
CCCP is offline   Reply With Quote
Old 09-13-2005, 06:54 PM   #2 (permalink)
View leasaunce's Photo Gallery
yeah, this is common on the camry. have you replace the stock struts or springs??
(try searching you might be able to find something else regarding with this problem)
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 09-13-2005, 07:05 PM   #3 (permalink)
yah ..... okay
View Neon's Photo Gallery
if the hear the sound from the back of your car.
it could be your sway bar bushing, try to relube it or inspect whether the bushing is torn somewhere.
*Image removed. Too big. You know the rules!* -Phi
Neon is offline   Reply With Quote
Old 09-13-2005, 07:47 PM   #4 (permalink)
View Gary_602Z's Photo Gallery
Why would the sway bar bushings create a rubbing sound? Check the stuts or springs being weak letting the tires rub on the inner fender wells.
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 09-13-2005, 08:10 PM   #5 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
guess u have not been on TN for too long.
Gen4 brusing does cause the rear to squeak.
some ppl used nautical grease and that stop it. search and u will find instuction to possible diagnosis.
that said, suspension (struts to struts mounts) can cause squeaks.
I would put my $$ on the brushing and / or strut mounts
have fun
skewe is offline   Reply With Quote
Old 09-13-2005, 08:58 PM   #6 (permalink)
Guess you ought to read the orginal post! He did not say squeak or squeal ! He said rubbing sound, I would presume that he would know the difference between a squeak/squeal and a rubbing sound! I stand by my reply with the info I was given.
Gary
Old 09-14-2005, 12:48 AM   #7 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
have you considered that the wheel bearing is starting to show signs of wear? perhaps a suggestion to go along with the others. also, can you see any rub spots at all?
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-14-2005, 01:47 AM   #8 (permalink)
drunken member
CCCP's Avatar
I don't see any rub spots at all, also I checked rear and front endlinks, they look fine. Is it normal for gen4 suspension to be too bouncy? Like comparing to my old 95 altima it's more bouncy, but still car handles great in turns and during quick lane changes, and it's nice and quiet.
Old 09-14-2005, 03:38 AM   #9 (permalink)
View yosh's Photo Gallery
Is your suspension modified in any way? When was the last time you replaced your struts?
2000 Camry LE V6
TRD Supercharged
yosh is offline   Reply With Quote
Old 09-14-2005, 05:02 AM   #10 (permalink)
View toyotarave's Photo Gallery
Hi Guys - got additional questions on weird sounds from my Camry - when it goes over uneven road surfaces - tend to create "karuk karuk" sound like absorber or spring hitting each other - but my mechanic checked and everything is ok - but he also mentioned that my front left boot cover is already loose and need to be replaced and might be the problem at hand.
When i get back to even roads it's very quiet like it should - I read in this post and some other posts in TN that the sway bar or bushing might need greasing - I'm not really into cars so if anybody got any photos to show where these parts are then I could get somebody to check these areas for my next trip to the workshop
Cheers!
toyotarave is offline   Reply With Quote
Old 09-14-2005, 04:25 PM   #11 (permalink)
View rainman's Photo Gallery
Can somebody recommend a good place to get Polyurethane swaybar bushings for a Gen3 I4. Most of the Internet stores only have them for 97 and above. I dont want to go for the normal rubber ones.
rainman is offline   Reply With Quote
Old 09-14-2005, 07:14 PM   #12 (permalink)
skewe's Avatar
Gary
as Original poster stated, "tire rubbing on body" sound
the brushing has rubber compound, so does the strut mounts...
it would cause that "Rubbing sound" aka squeaking sound.
if you do a search, you will find out that gen 4 brushing have caused problems with squeaking/rubbing sound.. and ppl have fixed that
yeah, so i did use a different terminology.
geee....
Old 09-14-2005, 07:16 PM   #13 (permalink)
skewe's Avatar
Cheers!
that would most likely be the strut mount or bump stopper.
The boot cover does not do anything except protect the struts from dust and dirt
