Stopping acid build up on positive battery node - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2005, 08:19 AM   #1 (permalink)
The Oddity
Aussie Ed's Avatar
View Aussie Ed's Photo Gallery
I have a minor problem. i've recently notice some acid build up on the positive node of my battery.
i washed it off last night with some boiled water and a tooth brush, but its back again today.
i don't know what's causing it. i have a feeling that it could be how my amp's fuse is wired to the positive node, but i could be wrong.
any ideas??
the battery is as old as my car so its 4 years old. i've had no problems with it before.
TN's Aussie Oddity, now with Evo 9 power??
Aussie Ed is offline   Reply With Quote
Old 09-14-2005, 10:18 AM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
solder a penny onto the top of the terminal or some small copper piece of metal. all of the corrosion will collect onto the copper and not of your lead terminal.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-14-2005, 01:32 PM   #3 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Use soda to clean it. Then spray with WD40.
mandyfig is offline   Reply With Quote
Old 09-14-2005, 01:48 PM   #4 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Use battery pads. They go between the terminal and the cable.
drunken_panda is offline   Reply With Quote
Old 09-14-2005, 02:05 PM   #5 (permalink)
Stock is not an option!
View greylock's Photo Gallery
All of the above or clean it with baking soda and then coat the terminal with wheel bearing grease. A bit messy but the grease sticks very well and is alkaline based to counter act acid buildup. Same thing with those battery pads. They are treated with some kind of alkaline chemical to counter act acid buildup.
greylock is offline   Reply With Quote
Old 09-14-2005, 03:27 PM   #6 (permalink)
Gen 4 XLE v6
jhbhatia's Avatar
View jhbhatia's Photo Gallery
^^ everything people said, there is a wire-gauge thingie you can buy at the autoparts store that cleans your terminals, i bought it when it was a dollar! It basically removes corrosion from the terminals after which you can follow the advises on top!
Desi Toyota Dude Here!!!
jhbhatia is offline   Reply With Quote
Old 09-14-2005, 08:33 PM   #7 (permalink)
View thoughthard's Photo Gallery
Goto a parts store, and ask for the good felt battery terminal washers that are treated to stop acid on the battery post. The ones behind the counter, in a small "paint can" type can. If they do not have them, or have no idea what you are talking about, look elsewhere.
When I used those, I NEVER had an issue with acid buildup.
thoughthard is offline   Reply With Quote
Old 09-14-2005, 09:19 PM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Are you refering to Corrosion build up? like white puffy grit?
Sounds like an acid leak in the battery, so you will need to check the electrolyte ( water/acid) level to make sure it is still good. I would look for cracks or see if the seal has separated at the post and case.
Is the battery old enough to replace under warranty?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
Old 09-14-2005, 09:49 PM   #9 (permalink)
mazdaverx7's Avatar
and if you're adding the water/acid(electrolyte), make sure you are using ONLY distilled water.
85 RX-7 GS 5spd
Old 09-16-2005, 05:35 AM   #10 (permalink)
The Oddity
Aussie Ed's Avatar
thanks for the tips guys. will give those a try.
my car is out of warrantee. i bought it new with the standard 3yr/100,000km warantee. so the battery is also out of warantee.
Old 09-16-2005, 07:04 PM   #11 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
battery acid pads are simple....all they are, are felt pieces with a jelly very very similar to vaseline so u have to 3 options....
1. buy a battery pad
2. buy a piece of felt and cut it appropriately and add vaseline
3. just smear some vaseline on the terminal....not that much is needed
problem solved
ag6286 is offline   Reply With Quote
Old 09-17-2005, 08:16 AM   #12 (permalink)
View glennsmga's Photo Gallery
battery corrosion fix
Hi folks. To get rid of fluffy white battery corrosion on your battery terminals, try this: First, make sure the battery posts and terminals are cleaned with a battery terminal cleaner. Use the wire brush type. Then, get some vaseline, and then mix ordinary baking soda into it. Mix in enough baking soda, so that the vaseline starts to change from clear to an off white colour. Now smear the vaseline/soda mix onto your battery posts and battery terminal connections. This should be done once a year, and is VERY effective at keeping corrosion away.
glennsmga is offline   Reply With Quote
