Japanese Engine Swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2005, 09:10 AM   #1 (permalink)
View 91CamryBlown's Photo Gallery
I recently blew the engine in my 91 Camry, 4cyl auto. I am looking into putting in a Japanese take out engine into it since they are well-priced. In putting this in my car, what should I watch out for? Any issues to keep in mind? Problems? Any help or advice or websites to make the process go smoother would be appreciated.
Thanks.
91CamryBlown is offline   Reply With Quote
Old 09-14-2005, 12:46 PM   #2 (permalink)
Banned
modifierLE's Avatar
View modifierLE's Photo Gallery
Well most toyota's are manufactured in the US. The only thing Jappanese Built now is the Engine and Transmission i think.
I think it should work fine. Becuse they are the same engine, except standards in US are different than japan. So you might run into some kind of problem with emmisions or something.
Sorry i dont have a proffesional answer, Just my opinion. Good luck with that. and welcome to TN
modifierLE is offline   Reply With Quote
Old 09-14-2005, 02:34 PM   #3 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
That's a JDM 3S-FE, you can search for specs on it. It supposedly boosts hp up to 140.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 09-14-2005, 08:45 PM   #4 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308675
It should pretty much bolt in. The only difference is the lack of EGR (possibly) on the JDM motor.
-Charlie
white90dx is online now   Reply With Quote
Old 09-14-2005, 09:25 PM   #5 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
I've used them before with good results. I would suggest replacing the timing belt/ water pump/ and seals before dropping it in. That way you will maximize the milage you will get out of it before having to anything else to it.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 09-14-2005, 10:15 PM   #6 (permalink)
The Other White Meat
terrastrife's Avatar
youll fail visual emissions if you have that (they hav eno egr) but they run cleaner then usdm and adm engines.
thats about the only real problem.
terrastrife is offline   Reply With Quote
Old 09-14-2005, 10:55 PM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
i don't think colorado cares that much about smog as if he was in california
Old 09-15-2005, 12:21 AM   #8 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
yea direct drop in, no problems...even more so if you use the original manifolds. thats actually the best bet.
wish ya luck with it. My Camry had one in it for about a year before it spun a bearing, same with another members.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 09-15-2005, 02:24 AM   #9 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $591657
iTrader Score: 7 reviews
View xpeed's Photo Gallery
Wouldn't you need to change the tranny and the location of the steering wheel column since it's a JDM engine?
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 09-15-2005, 03:46 AM   #10 (permalink)
no. its an engine, not a engine bay.
Old 09-15-2005, 05:04 AM   #11 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The only issue I see is with the EGR and number of bolts on the crank.
3S-FEs come with a 6 bolt or 8 bolt crank. The later ones are 8 bolt.
Just make sure whoever you buy the motor from gives you the correct flexplate/flywheel for the motor. You want a flexplate since you have a automatic.
Other then that, the motor bolts right up. You'll have to use your existing manifolds and accesories though, since the motor most likely comes as a long block (complete block and cylinder head).
"Skoolin' the unlearned!"
Old 09-20-2005, 10:58 AM   #12 (permalink)
Thanks for the info. I am in process of tearing it down now, I will let you know how it goes.
Old 09-20-2005, 06:33 PM   #13 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Good Luck!
BlueFusion6851 is offline   Reply With Quote
Old 11-20-2005, 07:44 PM   #14 (permalink)
View barthmonster's Photo Gallery
How do you buy parts once you've swapped in a Japanese motor??
Timing Belts, valve cover o-ring??
where do you buy them??
barthmonster is offline   Reply With Quote
Old 11-20-2005, 08:54 PM   #15 (permalink)
Art In Motion
Mayne Event's Avatar
View Mayne Event's Photo Gallery
so with that question, if I were to swap in a jdm 3s-fe and I needed a part for my car am I going to still get parts for a 95 camry OR am I going to need parts for a MR2?
There are no stupid questions, Just stupid people.
http://www.cardomain.com/id/badblood
Mayne Event is offline   Reply With Quote
