Shift solenoids - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2005, 12:02 PM   #1 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
Shift solenoids
Ok this has been pissing me off. After swapping to a 5 speed my ECU keeps throwing codes for shift solenoid malfunctions. I put in some 15 ohm, 25 watt resistors and it did nothing. Finally I just pulled the noids out of my old auto and plugged them back in to the wiring harness. The codes are still there even though all three perfectly working solenoids are actually hooked up. What Can I do? I thought of buying a Manual ECU but then I thought about it and realized that wont work either because I cant plug in an auto harness into a smaller port on the 5 Speed ECU. I need to get rid of these codes. What should I try now?
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 09-14-2005, 01:21 PM   #2 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Did you try resetting the ECU?
drunken_panda is offline   Reply With Quote
Old 09-14-2005, 07:08 PM   #3 (permalink)
97camryman's Avatar
Yeah I used a code scanner to reset it. Do the grounding points on the resistors have to be a certain distance apart?
Old 09-14-2005, 07:51 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ The person to ask is Ratko aka admin.
"Skoolin' the unlearned!"
