motor mounts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2005, 01:59 PM   #1 (permalink)
View hondakilla's Photo Gallery
2nd Generation motor mounts
does anyone know if the camry motor mounts were the same for the gen 2 - gen 4??? i have a 1990 camry and wanna put a 3sgte motor in it cause i need more power. i can't find anything saying if the 3sgte motor can/would bolt up to the camry motor mounts, so i don't know if anyone did it yet.
hondakilla is offline   Reply With Quote
Old 09-14-2005, 05:52 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The mounts on Camrys are different between the generations. Their also different between the motors (3S-FE, 2VZ-FE, 3VZ-FE, 5S-FE, 1MZ-FE, etc..).
You can use the mounts on your Camry or ones from a Celica All Trac / GT4.
3S-FE and 3S-GTE use the same basic block (3rd gen S block).
And you do have a I4 (3S-FE)?
"Skoolin' the unlearned!"
Old 09-14-2005, 07:56 PM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
^ read 88LE's sig
terrastrife is offline   Reply With Quote
