A couple quick questions... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-14-2005, 04:56 PM   #1 (permalink)
I Love Priuses
epinionator89's Avatar
View epinionator89's Photo Gallery
1) I was reading the user manual to my 1999 LE 4-cyl. and it says that "Your vehicle has a wireless remote control system that can lock or unlock all the doors, or activate the theft deterrent system..." I never recieved one when we bought the car in April. Did the key fobs come standard with all Camrys, regardless of trim level?
2) One last question--do they all come with "Engine Immobilizer Systems" as well? I don't see a "Security" symbol within the tachometer (see picture on page 10 for all Gen 4 owners) so I guess it doesn't.
Thanks--I should have know these things by now but they have been bugging me for weeks. If there have already been threads like this, please let me know (sorry if there is).
1999 Toyota Camry LE 4-cylinder
epinionator89 is offline   Reply With Quote
Old 09-14-2005, 06:21 PM   #2 (permalink)
View keithy's Photo Gallery
The one easiest way to tell is to look at the panel where the power mirror switch is and find the "toyota security", which has a led on it. If you car does have that, chances are that you do have an alarm. But to be sure, you have to find the "brain unit" of alarm also known as the ECU. The brain unit is normally located under the driver's seat or behind the mirror control switch panel. For year 1999 LE, the alarm or keyless entry comes as an option, I believe(correct me if I am wrong), either a dealer add on option, or a factory option.
Your second question, the "security" symbol in the tachometer might or might not be there, also depending if it is a factory installed or dealer installed. Usually, a factory installed security system will show on the tachometer. But dealer installed, might just be the LED "toyota Security' thing that I was talking about earlier.
Either way, you can give your local toyota dealer a call and ask them if you car have the keyless or alarm system installed. Be perpared to give them your VIN number when they ask. They have a database of the VIN and they can tell you if you indeed have a toyota security system or keyless installed.
All the information mentioned above only applies to toyota security system only. If it is an aftermarket alarm/keyless I don't have any way of telling if you do not have the FOB when you bought the car. Good luck and try taking good care of your toyota regardless if it has the system or not. Toyota cars are good cars!
keithy is offline   Reply With Quote
Old 09-14-2005, 09:43 PM   #3 (permalink)
MDT
View Maxemily's Photo Gallery
Not all Camrys had the Engine Immobiliser System installed.
If your Camry has Immobiliser it would have an indicator on the tach face that said 'security' independent of an alarm system. A factory alarm would share this indicator, while the RS3000 (dealer installed system) would have a seperate indicator as keithy stated.
The Immobiliser light in the tach would flash anytime the keys were not in the ignition.
Maxemily is offline   Reply With Quote
