which cat to get - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2005, 06:50 PM   #1 (permalink)
View camry300's Photo Gallery
which cat to get
I am trying to make up my mind on
1. carsound or magnaflow ( high flow generic )
or 2 an aftermarket direct fit cat
the only problem wiht the highflow cat is that , It is made for a 6 litre engine and I would have to cut off the flanges of the y pipe and the exhaust pipe leading to the muffler >Do You think there is enough support without the two flanges and use only clamps instead?
appreciate advise soon
camry300 is offline   Reply With Quote
Old 09-15-2005, 07:00 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
weld it in.
terrastrife is offline   Reply With Quote
Old 09-16-2005, 12:13 AM   #3 (permalink)
camry-4-ever's Avatar
View camry-4-ever's Photo Gallery
Use a Catco. They are guaranteed to pass emission tests, and still give you hi performance.
camry-4-ever is offline   Reply With Quote
