Installing oil pressure gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-16-2005, 12:48 PM   #1 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
So I am installing an autometer oil pressure gauge on my 5S right now and I want to just put a tee on the oil pressure sender and tie both units into the same location. But then later when I need to tap for the turbo oil feed do I just add on another tee to the side of the first to make three outlets, two for sensors and one to feed the turbo oil? Should I look for a 3 sided tee? What do you guys think?
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 09-16-2005, 07:10 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Uhh... T's are 3 sided.
You would need a X adapter (4 sides) or 2 T's joined together.
"Skoolin' the unlearned!"
Old 09-17-2005, 12:22 AM   #3 (permalink)
Gameroom cash: $147537
Is the oil sender hole too small for turbo oil? Will it have enough flow? Its only 1/8 BSP. Oh the hole is 1/8 BSP not NPT. The BSP is smaller and reguler pipe fitting will not go in.
Old 09-17-2005, 03:30 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
It works fine.
Old 09-17-2005, 06:06 PM   #5 (permalink)
97camryman's Avatar
Right I was asking if you could put one tee into another tee to make 3 outlets and one inlet. I guess this is acceptable then?
Old 09-18-2005, 02:37 PM   #6 (permalink)
97camryman's Avatar
One tee into another tee will be ok? It seems that it would be fine since the oil pressure gauge and the oil pressure sender dont actually use up any noticable amount of oil and the only thing sucking oil out of the three things is the turbo oil feed.
