I have a dillema.
I am not able to remove a spark plug in my car (spark plug closest to the battery).
I was planning to spend 15 min max and after 1.5 hours and no luck, I am not able to change one of the spark plug out. I used the spark plug remover (that t-shape tool I bought a long time ago from Autozone) and after pulling, pushing and hammering that tool with a rubber maller, i got nowhere. I even sat on the radiator beam and kicked that sucker (tool). NO LUCK!!!
I did install the other 3 plugs and yes, i did use anti seize grease.
Any help / ideas is greatly appreciated as I plan to attack it again later.
What does a repair shop uses in this case?
Car: 2000 Camry 2.2
Location of spark plug: Spark plug # 4 (spark plug closest to the battery)
THANKS!!!
