Please help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2002, 07:57 AM   #1 (permalink)
View guddn17's Photo Gallery
Please help!!
Hi
I have 2002 Solara with tires 215/55/16.
When I drive with 1~2 people on the back the tire rubs when I
go over bumpy and uneven road.
Is that because I have incorrect size of tire or it could be of suspension
problem? It only happens on the rear right side.
Thanks.
guddn17 is offline   Reply With Quote
Old 10-16-2002, 10:53 AM   #2 (permalink)
View PLRBEAR's Photo Gallery
Solaras should come with 205/60/16s, but 215/55/16s are the same overall diameter. I don't see a 10mm increase in tire width causing any fender rubbing on a stock vehicle.
Have you checked your tire for any scuff marks to find out if that's the area of concern? I do know that my 99 Camry's rear suspension is unbelievably soft, but i don't get rubbing with a full load behind. A test drive with a technician might be in order.
'99 Camry 5S-FE
PLRBEAR is offline   Reply With Quote
Old 10-16-2002, 11:18 AM   #3 (permalink)
View Tex97's Photo Gallery
My 97 Camry's suspension just plain sucks. the back end of my car is lower than it used to be but dealer says nothing is wrong. I thought i had the same prob you do but it turns out it was my imagination.
Dealer said that Camry's suspensions aren't the greatest and if i wanted a firmer ride i would have to go aftermarket. But i need money for that :x
97' Camry XLE V6
Tex97 is offline   Reply With Quote
Old 10-16-2002, 11:21 AM   #4 (permalink)
Oh yes, might want to check the tire pressures while you're at it. I firmed up the rear by pumping it up to 36psi, just handle extra loads when i need it. Works fine for comfort in my opinion. I've got the front pumped up to 34psi.
'99 Camry 5S-FE
