hmmm....you may be right....it sounds as though it's a pressure related problem...the vacuum should change noticeably even when the idle is increased slightly and when the throttle is off, the return should be immediate...
this does not have to do with the weak exhaust, but have you checked to see how much carbon deposits your throttle body has? perhaps it isn't opening and closing as properly as it should and perhaps not as wide as it should either in relation to the pressure that you put on the throttle
otherwise, I have no idea either....
HaHa
