--Upcoming Suspension Work - Fixing Noises too! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-18-2005, 09:13 PM   #1 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
--So far I have, KYB GR2's, Eibach Pro, New Rubber insulators on the front.
Okay, Im going to drop some cash into my suspension again. I want to get rid of the odd sounds when I hit bumps. I cannot isolate what its from, but "sounds" like it could be a strut mount problem.
What else can I do? New bushings, links, bumpers, rubber, etc? What am I looking to replace? Where? and Why? Anything else?
Also getting a whiteline sway bar for the rear, what else should I replace when I do that?
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 09-18-2005, 11:27 PM   #2 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
Definitely replace the mounts!! check your sway bar end links and the bushings themselves. on the rear sway bar, you would be looking at the condition of your control arms and make sure the bushings are good there as well. other than that, make sure you dont short change youself by missing parts or putting the car back together with crapola parts.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 09-19-2005, 05:20 AM   #3 (permalink)
Lex Zues!
RedPhoenix's Avatar
Are there differnt hardness of bushings? My links are fine, i checked them a few months ago, seemed okay. Bushings are iffy, probably should be replaced. Where can I get these? I think i saw them from whiteline?
Control arms are fine, bushings dont know, where can I get those for the control arm.
Strut mounts - KYB or direct OEM replacement? Whatever is cheaper? Because they should be the same, no?
Sold ^
Old 09-19-2005, 02:00 PM   #4 (permalink)
Lex Zues!
RedPhoenix's Avatar
bump
Sold ^
Old 09-19-2005, 02:50 PM   #5 (permalink)
TN's ExercisePhysiologist
Bunthy's Avatar
View Bunthy's Photo Gallery
red, I hear ya man. I just dropped my car recently too. I'm ridding on gr2 and vogtland springs. When I go over a bump I hear a sound from the front suspension, as if somethign is loose and about to come off. Shit man, I'm scared to drive my car now, really I am.
I took off the wheels to make sure the knuckle bolts are still there. They are and so are the 14mm that holds the strut mounts. I replaced one front mount a little while ago and I could tell the difference between the two (old and new).
You'll like being blown
Bunthy is offline   Reply With Quote
Old 09-19-2005, 04:02 PM   #6 (permalink)
Lex Zues!
RedPhoenix's Avatar
did the sound totally go away? can you explain? I feel safe driving it, but its kinda embarrasing when people are in the car.
Sold ^
Old 09-19-2005, 08:46 PM   #7 (permalink)
Lex Zues!
RedPhoenix's Avatar
bump
Sold ^
