3rd Brake Light - - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2005, 02:08 PM   #1 (permalink)
REAPER STRAIN's Avatar
View REAPER STRAIN's Photo Gallery
3rd Brake Light -
I am looking for the proper resistor for the 3rd brake light. I took this light out from the back window. The warning light on the dash comes on when I mash on the brakes. I read that all I need is a resistor to but in its place. I was at radioshack trying to find the right one and I got lost in the variety. I know that the light bulb is rated 12V, and 18 Watts. Using the Ohm's equation I got a rating of 8 ohms. Is that right? Can I use a 10 ohm/ 0.25Watt resitor? If not what can I use?
REAPER STRAIN is offline   Reply With Quote
Old 09-19-2005, 04:56 PM   #2 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
You cannot use those dinky 1/4W resistors.
Think about it. You want to mimic the bulb still being there. So if the bulb was pulling 18W, you want your resistor to pull around 18W as well(its probably ok to use as low as 12W if you can't find 18W). The resistor you're looking for will look more like this:
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 09-19-2005, 05:46 PM   #3 (permalink)
That thing is pretty big. So, long story short, I need resistor that is at least 12v and any ohm rating over 8 right? Anything else?
Old 09-19-2005, 05:50 PM   #4 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
just watch the heat output very closely...
what you can do to get around this is connect the positive and negative from that 3rd brakelight to the positive and negative from one of the rear taillights. that solves the heat issue, and you dont have to buy anything, besides wire.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 09-19-2005, 05:57 PM   #5 (permalink)
0111010010
SnakeyeS's Avatar
^ that should work as well
Old 09-20-2005, 02:14 AM   #6 (permalink)
in terms of hear outputs what would you suggest? Im really leaning towards installing the resistor instead running wires to the brake lights because I maybe getting a rear spoiler soon with a built in light. So inserting a resistor would be ideal.
So, from what all are saying is I need a resistor with a low heat output, more than 12v and 8 ohms rating and I should be set right?
Im looking at radioshack.com and all I see are these lego size resistors. That cant be right can it? They look like the metal one in the picture above.
http://www.radioshack.com/category.a...4%5F004&Page=1
Old 09-20-2005, 03:49 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
I would use atleast a 20W or 25W resistor.
8 ohms should work.
Those are ceramic wirewound resistors.
The one that snakeyes posted has a integrated heatsink.
Try a electronics supply shop. Radio Shack lacks on electronic components.
"Skoolin' the unlearned!"
