Universal Catalytic Conv. Is there a break in peirod? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2005, 06:40 PM   #1 (permalink)
DLo
You make me stupid.
View DLo's Photo Gallery
I jus put on a new cat on my camry about a week and a half ago and I can now and then smell a smell like the cat is going bad. It is new from the shop, but Universal. I wanted to know if there is a break in peirod where there will be a smell issue like the old one, or if this is a common issue?
Thanks all.
DLo
DLo is offline   Reply With Quote
Old 09-19-2005, 09:12 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
sur eyou dont have a leak b4 the cat?
my magnaflow doesnt smell at all ^^
terrastrife is offline   Reply With Quote
Old 09-20-2005, 09:43 AM   #3 (permalink)
Flagrant Fouler
Diehonda's Avatar
View Diehonda's Photo Gallery
smells strange, like hot fiberglass? If you know what that smells like. Some universals heat up more than OEM causing a smell. It should subside after a few weeks after installation, but if you drive on the highway for awhile and WOT a few times right before stopping, at an exit, etc. You will smell it again. They just do that. It never hurts to check for leaks though. I have a HiFlo universal on my Jetta. After driving at over 80mph for awhile (15 minutes or so) I smell it a little bit, had it on there for about 15K so far. May cause you to go thru after cat 02 sensors faster too. When I tried to save a bit and use universal 02 sensors for after cat I ran through them, switched back to OEM and it is all good now.
Free Gen 2 Camry book for anyone coming through Louisville, KY
Diehonda is offline   Reply With Quote
Old 09-20-2005, 02:11 PM   #4 (permalink)
DLo
You make me stupid.
Thanks Diehonda, that is in a nutshell what was going on. Close to WOT on highway or at highway speeds and then backing down to 3/4 gear wile comming to a slow or stop intown. It has allready started to go away....if not to jus a faint almost nothing.
Thanks to all though.
