Originally Posted by deekay140
Its Built Into The Neutral Safety Switch, Which Is On The Trans.
Thank you, deekay140. I didn't believe your answer when first seeing it, as my manual says there is a seperate back-up light switch. After many trials and errors, and after calling the dealer, now I realized how correct you were.
The Neutral Safety Switch seems an expensive unit. Before changing it, I guess I should make sure it's defective. If it's the problem with the PNP switch (neutral safety switch), do you think I will get an error code when using a ODB meter to read it? (The "check engine" light doesn't light up in my car.) The car still backups OK, do you think a defective switch can have the proper backup function but without lighting up the back-up lights?
Is there a simple way to test the PNP switch specifically for the back-up light circuits? Thank you very much.
