is wd40 sensor safe? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2005, 04:27 PM   #1 (permalink)
View camry300's Photo Gallery
is wd 40 sensor safe? I mean O2 sensor safe. I would like to clean my PCV valve with it ( leaving the PCV still on the car)
camry300 is offline   Reply With Quote
Old 09-21-2005, 04:57 PM   #2 (permalink)
View foompla's Photo Gallery
why?
foompla is offline   Reply With Quote
Old 09-21-2005, 08:44 PM   #3 (permalink)
because I will spray wd40 into the pcv valve to clean it.
Old 09-21-2005, 08:49 PM   #4 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397685
View RningOnFumes's Photo Gallery
but the pcv valve is easy to take out...and soak..in fluid.
how will you know it's bad or not if you don't take it out and shake it?
edit: ...and isn't it cheap enough to buy?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 09-21-2005, 08:52 PM   #5 (permalink)
Gameroom cash: $369176
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
I used wd40 to clean my PCV valve. I think I used Carb cleaner on my o2 sensors
RichieRichJP is offline   Reply With Quote
Old 09-21-2005, 10:03 PM   #6 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Why don't you just pull it out..literally, it just pulls out...1 second job...makes for a better clean too. O2 Sensors need to be un-bolted, but even then, its soo simple. But yes, WD40 is sensor safe.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 09-22-2005, 11:43 AM   #7 (permalink)
Gameroom cash: $304455
I'm not sure if it is O2 sensor safe, but as others have stated, why risk it at all. It does take only a second to remove the PCV valve for cleaning or replacing. Use something to clean it like carb cleaner which is marked on the can "O2 sensor safe". PCV valves are cheap and very easy to replace. O2 sensors are not nearly as cheap or as easy to replace. IMHO.
Mike
Mike Gerber is online now   Reply With Quote
