Noisy AC Compressor (I Think) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2005, 09:57 AM   #1 (permalink)
View zotparkerm's Photo Gallery
At idle, there is a rattling/knocking noise which goes away if I turn off the AC.
Any suggestions on what to check? Bad belt, compressor, low R134? What should I check (and how, if it is not obvious)?
Thanks.
zotparkerm is offline   Reply With Quote
Old 09-22-2005, 11:02 AM   #2 (permalink)
View tightcamry129's Photo Gallery
i'd first suggest, the belt tension...
tightcamry129 is offline   Reply With Quote
Old 09-22-2005, 12:01 PM   #3 (permalink)
View Lord Anonymous's Photo Gallery
The bearing of the compressor's pulley.
94' Camry L4, 540'000 kms (~337'000 miles)
93' Camry L4, 253'000 kms (~158'000 miles)
95' Camry V6, 240'000 kms (~150'000 miles)
Salutations from France
Lord Anonymous is offline   Reply With Quote
Old 09-22-2005, 02:48 PM   #4 (permalink)
Can the compressor bearing be replaced (without replacing the whole compressor) if it is that bearing?
Old 09-27-2005, 03:44 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I have heard that you can add oil to the r134 but there are two types, PAG and Esther(?). PAG has multiple weights. So you would need to find out what you have in there first. You're not going to add much, an ounce or two
There is an additive called ICE 32 that you may want to see if it is compatible with your system. It has a good reputation. Add one ounce.
Luck,
Kep
Old 09-27-2005, 10:00 PM   #6 (permalink)
Moving Forward
View Cyorke's Photo Gallery
What year model is the car. They had some problems with loud compressors on Gen 3's. I got so tired of telling people that it was normal operation when I was working on them. NO matter how many we would put on to try and cure the problem it was always there.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 09-27-2005, 10:18 PM   #7 (permalink)
camry-4-ever's Avatar
View camry-4-ever's Photo Gallery
Mine is a 99 and has the same problem. Anyone tackled this one before?
camry-4-ever is offline   Reply With Quote
Old 09-27-2005, 11:33 PM   #8 (permalink)
View azz419's Photo Gallery
if it was a bearing in the compressor, i would guess that it would more than likely be the pulley one, which it can't be because it would be making the noise all the time (the pulley runs all the time) I would check the clutch on the compressor, the refrigerant level, and if the sound really is the compressor (maybe the fan inside switching with compressor?) Most shops will charge you a new compressor, not repair.
azz419 is offline   Reply With Quote
