malfunction indicator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2005, 08:52 PM   #1 (permalink)
View attaboyren's Photo Gallery
Unhappy malfunction indicator
My 1998 Camry's malfunction light comes on and I found the temp. under the hood is very high.
What's the problem? The fuel cap is tight, so I think something wrong under the hood.
Thanks!!!
attaboyren is offline   Reply With Quote
Old 09-23-2005, 01:44 PM   #2 (permalink)
Gameroom cash: $304355
Take it to Autozone. They will read the codes for you for free. Then report back here with the code and someone should be able to offer you some suggestions.
The temperture under the hood is normally pretty high. I doubt that has anything to do with the malfunction indicator light (MIL).
Mike
Old 09-23-2005, 03:04 PM   #3 (permalink)
Thanks a ton! I will post what's going on.
Old 09-23-2005, 10:22 PM   #4 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
Make sure you buy something while you are in Autozone. Think of it this way, you'd probably have to spend 80 bucks or so to have a shop diagnose your problem, and they are doing it for free. Give them a little thanks by buying something, anything. Even if it's only like 5 bucks, it shows appreciation.
That way, they'll continue this awesome service. And no, I don't work for Autozone.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 09-24-2005, 08:35 AM   #5 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
They dont diagnose the problem, they just tell you the code number. The one by me has a bad habit of guessing when it comes to diagnosis. Just depends on the people that work there i suppose, but we can help you with the diagnosis part once you have the number.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 09-24-2005, 02:23 PM   #6 (permalink)
We can all go here, once we have the code number:
http://www.iequus.com/obd_def.asp
Mike
