Tried Many things, Rumbling Noise still There. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2005, 08:58 PM   #1 (permalink)
5spd V6 ClrTail's Avatar
View 5spd V6 ClrTail's Photo Gallery
Few months ago i posted about the annoying rumbling and humming i get when the weight shifts on the left rear tire, that is when I make a left turn or I'm takin a left curve at speed. Yesterday I changed the wheel bearing and stabilizer bar link. Also tried a different rim. The rumbling noise is still there. Could it be a simple balance and alignment problem. Or should I get a whole spindle assembly and see what happens?
5spd V6 ClrTail is offline   Reply With Quote
Old 09-23-2005, 09:18 PM   #2 (permalink)
View glennsmga's Photo Gallery
Canada Rumbling eh?
Are you sure the rumbling is coming form the rear? Soundsl like it could be a front wheel constant velocity joint or hanger bearing on the shaft. Cheers! GLenn
glennsmga is offline   Reply With Quote
Old 09-23-2005, 09:20 PM   #3 (permalink)
View joel_musicman's Photo Gallery
Balance/alignment issues AFAIK would change with speed, not so much weight transfer. Normally this will present as a "wooh-wooh-wooh" sound that changes with speed, or a vibration in the chassis at certain speeds. Wouldn't hurt to have it inspected though.
How many miles on the tires?
-Joel
My new baby! 2007 Toyota Camry SE V6 - Super White
'99 Camry LE, Reverse Glow Gauges, Strut Brace, & Infinity Basslink
joel_musicman is offline   Reply With Quote
Old 09-24-2005, 10:30 AM   #4 (permalink)
View Gary_602Z's Photo Gallery
Check the right side! If you make a left turn the weight is transfered to the right side.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 09-24-2005, 12:44 PM   #5 (permalink)
Sorry, it's the Right Rear Tire that makes the noise. When I turn left and the weight shifts on that tire, it makes the rumbling humming noise. Also, when going 70mph or more theres a vibration that comes from that tire also. Very annoying. Should I get a whole spindle from another car?
Old 09-24-2005, 06:10 PM   #6 (permalink)
If you have changed the right rear bearing and race then I don't think you would have to change the spindle as that is a non moving part. I would shift my efforts toward the right front bearing. Are you sure it is not an exhaust vibe?
Gary
Old 09-24-2005, 07:58 PM   #7 (permalink)
no, not exhaust vibe. Cuz there's bibration at speeds above 70 mph, that generates from that right rear tire. I mean, i can have the front wheel bearings checked out. But definately all the noise is coming from back there.
Old 09-24-2005, 08:14 PM   #8 (permalink)
The Other White Meat
terrastrife's Avatar
if its coming from the tyre, try getting the tyre rotated/balanced again.
terrastrife is offline   Reply With Quote
Old 09-24-2005, 09:16 PM   #9 (permalink)
Will alignment help? Car hasn't been aligned in well over 2 yrs.
