Steering wheel
Yeah just about any Yota wheel will fit. I've considered changing mine too to a Lexus Wood wheel. They're not too expensive, but it's the airbag that will get you. Check to see if the ES300 wood wheel is the same pattern, then you could still use your airbag.
Note on airbag connectors. I've yanked out plenty of bags without disconnecting the battery. Toyota connectors automaticly short together when disconnected to discharge any spark that would set off the airbag. Very smart design. Also you need a long torx bit to reach into the bolt that holds the airbag, one on each side. usually theres a square plastic cover that you need to pop off on the back side of the wheel to access the bolt heads
90' ES two-fity, balanced motor, head work, home built intake, lowered, wheels, window tint and some stereo upgrades, next...building my headers.
