I tried to take out the fornt wheel for brake cleaning, but there is a rusted metal clip that lock the wheel in position. Is it alrite if I remove it? Will it affects handling and performance? I mean, if I drive too or too much cornering, the front wheel might loosen? Thanks for helping
2010 Venza V6 AWD / Magnetic Grey Metallic / Navi and JBL Package
There's a clip holding the front wheel? Shouldn't it be only 5 nuts? If you mean the clip that holds the main hub nut cover, then yeah, you can remove it, and then replace it with a new "splitpin" after, if thats what your mean...
__________________ 1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
If I don't replace it, will it be dangerous?
Yes it will. It is designed for safety, so the hub nut does not spin off. It physically can't under vibration with the pin there. So definetly replace it when your done.
Thanks for the advice. So, any ideas where to get it? Is Canadian Tire okay?
You should bea bel to go to nay auto parts store and get a new cotter pin to put in there. Just install it ehn make sure you bend it so it doesnt fall out. It is there to prevent the axle nut from vibrating loose.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Nevermind guys, I can take the wheel out. I must be thinking too much...
But is there any specific place where I should not spray the brake cleaner? Thanks!
jsut spray wherever you want to. Youarent going to hurt anything. Unless you take caliper pins out then you dont want to wash the grease off of those. If you do jsut grease them again so they can move freely.
Chris
