gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2002, 07:16 PM   #1 (permalink)
Newbie
smokey8890's Avatar
View smokey8890's Photo Gallery
gauge
i just installed my reverse gauge in my carmy. for some reason the reverse indiglo gauge was in the indiglo package. oh well. when installed it using rayray guide. (thanx rayray) at first i used the green and white wire like he said. but on my test drive when i shirt to drive the lights went out. :o i took it apart and instead used the black wire. then when i took my second test drive i notice something wrong. no needles! :o i couldn't figure it out. then i played with the dimmer suddenly the needles came up. but........ the gauge was gone. so what wire should i use as power? i would like it to power up whenevery my headlights are on. but with needles. help me ouat if anyone ccan.
I miss my camry....................
smokey8890 is offline   Reply With Quote
Old 10-20-2002, 11:25 PM   #2 (permalink)
rayray's Avatar
View rayray's Photo Gallery
if you look at the pic below...
http://www.imagestation.com/picture/sraid17/pf40e551c8b24387542aaa52b946866f3/fdfb5736.jpg.orig.jpg
you'll see that i'm using a tester to test the light out. when the light goes on... then there's power running thru the wire. then you trun on/off your headlights to see if the tester does the same. then try your dimmer and see if the tester does the same.
i ended up using the second wire from the top... of the brown plug that goes into the middle part of your gauge cluster. i'm not too sure of the color of the wire... but i think it's green w/ white stripe.
make sure you test the wire while you got it out. then check that all your plugs are in securely and that all your wires are solidly connected.
good luck!
-rayray
rayray is offline   Reply With Quote
Old 10-21-2002, 10:37 AM   #3 (permalink)
Call me DR. DIY or SHGUN
View Bigshoguns's Photo Gallery
smokey i had a similar prob. but i really done f**ked up. oo yeah THX rayray. your guide helped me out alot. i have a gen4 thou.. but the wiring helped me out.. thx dude..
smokey if u find a cure let me know..
Bigshoguns is offline   Reply With Quote
Old 10-24-2002, 11:37 AM   #4 (permalink)
Hey smokey Did u get ur problem fixed.. i got mine working will have pics soon. I used the Green W/ white wire as power, the black one as ground and there's a White w/ green one i left it alone. and now my gauges light up when the headlights go one and turn off when i open my door(gen 4+ feature it think). but if u want contact me on aim and ill help u out. o yeah.. these wire go to the stock dimmer and the power is switched not constant which is good. u can either use the harness behind the gauges(brown harness) or the dimmer harness(3 plug black harness) and it will work flawlessly
Old 10-24-2002, 07:15 PM   #5 (permalink)
Blazin...
SCEPTER300RR's Avatar
View SCEPTER300RR's Photo Gallery
im using the power wire from the fuse box ( brake light or rear parking lights which switch on when i turn on the lights) i got the wiring diagram from teamsc3 they have a full write up on it... no problems since then.. btw the dimmer switch on ur car wont work no more... good luck dude...
humpty
Neoscepter
SCEPTER300RR is offline   Reply With Quote
Old 10-24-2002, 11:22 PM   #6 (permalink)
View Zeek321's Photo Gallery
im using the power line that lights up the dash lights, use that one, its the easiest... its the last one on the right,on the middle plug of the three that go into your dash.... sounds like the same one rayray used...
It's a midwest thaaang!!!
http://www.imagestation.com/album/?id=4291436091
Zeek321 is offline   Reply With Quote
Old 10-26-2002, 05:43 PM   #7 (permalink)
Actually the Dimmer does work. and the gauges work fine now i have two dimmers for the gauges. this was the easiest thing i ever wired in my car. ill have pics up soon
