Looking for a new motor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2005, 05:50 PM   #1 (permalink)
View The Black Camry's Photo Gallery
I Have a 1990 Camry with the 3sfe engine and i want to swap it out for the 3sgte. i just wanted to know if that would be a good idea and where i could get one cheap. Thanks!
The Black Camry is offline   Reply With Quote
Old 09-25-2005, 06:05 PM   #2 (permalink)
Call Me Evolution Racer
TRDCamryCL's Avatar
View TRDCamryCL's Photo Gallery
3S-GTE aren't that expensive. In fact they are very common. With money, anyone can pull off the conversion.
- 5QU1NTYC4MZ - #1 BOOST WAY OR HIGHWAY Camry project is over and no more.
2004 VW GLi 1.8T w/ GT30R.
TRDCamryCL is offline   Reply With Quote
Old 09-25-2005, 06:11 PM   #3 (permalink)
Well do you know where ( on the web) i could get a hold of a cheap one? and what trans would i need. its a 5 speed.
Old 09-25-2005, 06:20 PM   #4 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
You could use the transmission that you have in there already, but it probably wouldn't hold up to the 70 extra horsepower for too long. You could use a transmission out of a similar year Celica, though I'm not sure if they're much stronger.
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 09-25-2005, 06:24 PM   #5 (permalink)
But what tranny should i upgrade to? and where can i get the engine and trany for cheap?
Old 09-25-2005, 06:35 PM   #6 (permalink)
TRDCamryCL's Avatar
What is your price range? Define "Cheap"
Old 09-25-2005, 09:58 PM   #7 (permalink)
You can use an E153, it has been proven to be usable in the VZV21 platform so the SV21 should be able to use it. The E153 is the Camry/Solara 5 speed tranny and also was used in the MR2 turbo in a modified form (shift linkage on the opposite side).
Old 09-26-2005, 12:20 AM   #8 (permalink)
about less than $1,000 !
Old 09-26-2005, 01:15 AM   #9 (permalink)
The Other White Meat
terrastrife's Avatar
ebay. but yorue ebtter off getting it local.
and if 1k is your budget, keep saving. youre gonna need more then that.
best off getting a complete front clip off an old celica.
terrastrife is offline   Reply With Quote
Old 09-26-2005, 01:42 AM   #10 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
No way your gunna find a clip for less then a $1,000.
Your looking at least $1,500 depending on what engine comes with the clip.
225 hp 3S-GTE is around $1,500 for a clip.
245 hp 3S-GTE is around $3,000 for a clip.
Theres also a 260 hp version used in the Caldina.
The specs are for 3S-GTE's imported from Japan. US version makes less power.
Clip = MR2 Turbo or Celica All Trac / GT4.
"Skoolin' the unlearned!"
Old 09-26-2005, 05:57 PM   #11 (permalink)
View keylogger's Photo Gallery
Where is "Caldina"?
Willing to learn from "experienced" tunners. I just need the parts.
keylogger is offline   Reply With Quote
Old 09-29-2005, 11:56 AM   #12 (permalink)
damn, do you know of a good reliable web site were i could find the 260 hp verson of the 3s-gte? and were is caldina?
Old 09-29-2005, 05:30 PM   #13 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $308075
Where is "Caldina"?
Try "searching"
Old 09-29-2005, 05:33 PM   #14 (permalink)
white90dx's Avatar
The Caldina is a car made by Toyota in Japan.
You'll NEVER pull this project off with less than $1k. You need the motor, wiring harness, ecu, possibly a tranny, axles, and many other parts.
If you have a shop do the work, you probably won't get out the door for less than $5k. These are not Honda swaps.
-Charlie
Old 09-30-2005, 12:00 AM   #15 (permalink)
i guess i have to start saving up!
