FE vs. GE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2005, 09:21 PM   #1 (permalink)
View MattL's Photo Gallery
FE vs. GE
Just like all car manufacturers, I know Toyota has different sized engines with different # of cylinders, and Toyota classifies them as families. Anyways, my question was what is the difference between FE and GE? What part of the engine is this and what makes them different? All I've heard of and know is that you can modify the GE engines quite a bit but not the FE engines. Care to shed some light?
MattL is offline   Reply With Quote
Old 09-25-2005, 09:38 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
The F and G are more in relation to the cylinder head design.
A F engine is economy oriented and the G is performance oriented.
G = twin cam (wide angle, 45 degrees or more between the intake and exhaust valves)
F = "economical" twin cam (narrow angle, around 22 degrees
http://www.geocities.com/MotorCity/P...gineCodes.html
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 09-25-2005, 10:52 PM   #3 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The FE head is a narrow angle twin cam head. It is designed for high torque and power in lower RPMs and helps provide good fuel economy. The timing belt or chain drives only one of the cams in the head. The other is driven by gears.
The G head has a wider angle. The two cams are both driven by the timing belt. This allows independent adjustment to the timing. The engines with GE heads have more power, but that comes at higher RPMs. They have less power at lower RPMs generally.
2007 Camry 2.4L 5M
Old 07-31-2006, 02:02 AM   #4 (permalink)
Kliddybaba!
fistofmeat's Avatar
View fistofmeat's Photo Gallery
i assume then that both the ae92 sedan and the coup have the same top speed, but the coup just accelerates a bit faster, please correct me if im wrong
fistofmeat is offline   Reply With Quote
Old 07-31-2006, 02:58 AM   #5 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
