Another clunking suspension thread - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2005, 01:27 AM   #1 (permalink)
View Jimmyjames's Photo Gallery
Australia Another clunking suspension thread
Howdy all.
I recently bought a 99 Camry Conquest with almost 100,000kms on it. It was a company car and well looked after but the only thing that was not quite right was some clunking sounds from the front suspension. More obvious on one side that the other.
I had a bit of a read about these sounds and have found a lot of people are having the same problems with their Camrys especially around this age and mileage. It appears that at least 4 different threads have specified replaced the Front Strut mounts and this seems to sort out the problems. I would do this only I then read that this doesn't always seem to be the case and I have also read that
"1997–1999 models: a missing rubber bushing in the front upper strut mounting can cause front suspension knocking."
Question 1. I am fairly technically minded and I have access to most tools. How difficult is it to replace the strut mounts?
Question 2. How confident can I be that this will solve the problem.
Question 3. Anyone ever heard about replacing these rubber bushings and did it solve their clunking problems?
I know it's not CV noise as I know that noise. The sound would be best described as a hollow clunking sound that mainly happens if I go over speed humps or potholes. It really does sound like something (heavy) is loose. I have done a basic visual and all looks OK.
Any advice would be greatly appreciated by this newcomer.
Jimmyjames is offline   Reply With Quote
Old 09-26-2005, 01:43 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
the strut mount is $20 from the dealer and itll take about 20 minutes or less with a rattle gun
jack up the car
take the wheel off
3 upper and 2 lower sturt bolts
change
process backwards.
just remember, dont pull downards too hard on the hub when you tak the strut out, youll pull the shaft out of its joint.
terrastrife is offline   Reply With Quote
Old 09-26-2005, 05:56 PM   #3 (permalink)
View steve97's Photo Gallery
Must ask yourself the question, "if I am going to the trouble of changing the mounts, is it time to change the struts too? And how about the top and bottom insulators? And the strut bearing? What about the spring? Then you must think about the other side as well...So you see, it quickly gets out of the $20-30 range.
steve97 is offline   Reply With Quote
Old 09-26-2005, 06:31 PM   #4 (permalink)
The Oddity
Aussie Ed's Avatar
View Aussie Ed's Photo Gallery
the solution depends on what you want to do and how far you want to go with it.
are you planning on modifying your camry?
if yes, i'd get sports shocks and lowered springs in the process of fixing the noise problem. to improve the overall handling of the car.
if no, just fix what needs to be fixed. if it ain't broke don't fix it.
TN's Aussie Oddity, now with Evo 9 power??
Aussie Ed is offline   Reply With Quote
Old 09-26-2005, 06:45 PM   #5 (permalink)
View leasaunce's Photo Gallery
its not that difficult to change the strut mounts if you have the right tools. I when my mechanic did it for me, i watched him do it and took him less than 10mins on each strut mount.
But i have experienced this problem before and changing the strut mounts will not clear the clunking sound. It will reduces the clunking sound. The problem is not with the rubber bushings, its the bodypanel.
You can replace all of them but trust me you will still hear some clunking noise.
hope this help.....
Custom CAI ll Borla Cat-Back Exhaust ll DIY Needle Colour ll
ll TRD Bodykit ll Sports Springs ll Chrome Grill ll GEN 4.5 HEADLIGHTS w/PROJECTORS ll
leasaunce is offline   Reply With Quote
Old 09-26-2005, 06:51 PM   #6 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
jack up the car
take the wheel off
change
process backwards.
$20?
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 09-27-2005, 06:06 PM   #7 (permalink)
Thanks People
Thanks for all of your help people.
I will jack up the car this weekend and have a look at what tools I need and then will try this during my lunch hour at work some time next week. Interestingly all of the company cars are Camrys (around the same age) and a few of them have this problem. Some of them have had the struts replaced and the sound has gone away temporarily only to return soon after (although not as loud).
Also interesting is Leasaunce reply which suggests that a body panel is the main cause of this noise. I'd love to hear exactly what panel and if there is anything that could be done.
I don't intend to keep this car for more than a year so I don't want these sounds happening when someone is taking it for a test drive. I also don't intend lowering it or spending too much money on it.
Cheers
Old 09-27-2005, 06:13 PM   #8 (permalink)
View Ranger X's Photo Gallery
The body panel?? Expalin, please! I just don't see how a body panel could be the cause of such a noise, when there is no noise at all until around the time that the strut assemblies wear out. I'm having the same exact problem, so I'd like to know what's going on.
Ranger X is offline   Reply With Quote
