2VZFE knock sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2005, 07:46 AM   #1 (permalink)
View dubster23's Photo Gallery
2VZFE knock sensor
I currently have a 1991 camry V6 and the motor fried. I found another motor but this one does not have the knock sensor on it? Is there a way to make this work somehow? Thanks for any info you have?
dubster23 is offline   Reply With Quote
Old 09-26-2005, 12:10 PM   #2 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
take ur old sensor off and put it on the newer block if it's still good, not too hard of a job unless ur a noob at this stuff. You will need a knock sensor in the newer block.
ag6286 is offline   Reply With Quote
Old 09-26-2005, 02:14 PM   #3 (permalink)
The problem is that the motor I got to replace the bad one does not have a place for it. Is there a way to eliminate it? Thanks
Old 09-26-2005, 03:43 PM   #4 (permalink)
then u dont have the right motor? it must if its another 2vzfe. Before i go much further about this...do u even know wer the knock sensor is located for sure??? wer'd u get teh motor from? what kind is it? etc
Old 09-26-2005, 04:00 PM   #5 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
Not all 2vz have knock sensors. Only the USDM motors were equipped with knock sensors. The ones made in 88 and 89 don't have them, but the 90 and 91 models do.
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 09-27-2005, 03:45 PM   #6 (permalink)
^ hmmmmm.............interesting
Old 09-28-2005, 10:07 PM   #7 (permalink)
So is it feasible to remove/bypass the knock sensor? What will happen if I just plug it in and zip tie it there?
Old 09-28-2005, 10:22 PM   #8 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Your ECU will no longer be able to detect knocking/detonation, which can cause you to blow a hole through your pistons.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 09-28-2005, 10:50 PM   #9 (permalink)
dunno about the hole in the piston but ur engine would run quite limp unless u tricked into thinking it was ther by adding an appropriate resistance on the line for the knock sensor...im not sure exactly how the ECU works so that may be a possible solution....
or simply locate an ecu for the engine w/o and knock sensor in it at a junkyard....possibly another solution
Old 09-28-2005, 10:56 PM   #10 (permalink)
VeeZed
When i said "blow a hole in your piston", if you are running an excessive condition, then yes, it can, and will blow a hole....the knock sensor is there to provide detection and prevention of such a problem, i.e. retarding this iginiton advance.
Old 09-28-2005, 11:34 PM   #11 (permalink)
i understand wut the sensors do, i already have a huge problem with them myself with my 3vz-fe in the fact NEITHER of them (both brand new) register with the ECU.....but please define 'excessive condition'
Old 09-29-2005, 01:04 AM   #12 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
^ suddenly going to WOT and dropping 2 gears, and bouncing off your rev-limiter
if you were running lean as it was, that would at the very least give you some bad rod-knock if your ecu doesn't start dumping fuel in
but back on topic, you can always just use a tap and create a mounting spot for the knocksensor
HaHa
Old 09-29-2005, 02:00 AM   #13 (permalink)
^^understood, but the only time ud have to worry about that is if u had 5SPD or ur auto transmission gear slips after which it would pretty much be destroyed....been ther, not fun, and VERY costly
didnt really think abou tthat with my knock sensor problem , good thing i have the auto for now
