Help!! My Car Died! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-26-2005, 09:16 AM   #1 (permalink)
camry-4-ever's Avatar
View camry-4-ever's Photo Gallery
Unhappy Help!! My Car Died!
I was trying to get my family back to Houston, after Rita passed. Started towards the highway and only got a couple miles when the Camry started chugging and then shut down. Luckily my wife's cousin was still close enough to come get us. My wife is pregnant so we got her back to her cousin's houseand me & the cousin's husband limped the Camry back. I hadd to keep pumping the gas pedal to keep it from shutting down. Anyone know what could cause this?
camry-4-ever is offline   Reply With Quote
Old 09-26-2005, 09:41 AM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
hard to say. Dirty fuel filter. Fouled plugs. Stuck TB. EGR. Do you have an I4 or V6?
ps- glad to hear you and your family are safe.
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 09-26-2005, 03:17 PM   #3 (permalink)
Thanks, I have a 99 4 cyl. Please, If someone can help the garage says so far they can't find anything!!
Old 09-26-2005, 03:27 PM   #4 (permalink)
Gameroom cash: $304355
Glad you and your family are OK.
Have the garage put a fuel pressure gage on the fuel rail to check the fuel pump and the fuel pressure regulator.
Mike
Old 09-26-2005, 03:46 PM   #5 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
excessive moisture disrupting spark perhaps?
Old 09-26-2005, 04:05 PM   #6 (permalink)
They said they saw arcing between the plug wires. But would that cause it to die?
Old 09-26-2005, 04:06 PM   #7 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
map sensor? No CEL?
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 09-26-2005, 04:10 PM   #8 (permalink)
View Gary_602Z's Photo Gallery
Yes! You should have mentioned that in your first post. What kind of shop is this anyway?
Any shop that is worth their salt would know this. It may not be all of your problems but it should be fixed first.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 09-26-2005, 05:49 PM   #9 (permalink)
View karazy's Photo Gallery
Wow As a temporary fix, you can try spraying the wires with WD-40 to remove the moisture, but replace the wires ASAP.
karazy is offline   Reply With Quote
Old 09-27-2005, 09:21 PM   #10 (permalink)
Okay so I'm thinkin of having the shop replace the stock spark wires with NGK and put new NGK spark plugs in, replace the fuel filter, and possibly replace the cat. If I go with stock parts it will be around 900 USD. Stock cat. costs$600. Thinkin about using a catco cat. Anyone know if I have that choice or pretty much have to stay with parts from the dealer?
