'Clean up' front rotors? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2005, 03:09 PM   #1 (permalink)
View NCGuy68's Photo Gallery
I'll be replacing the front brake pads on my 96 Carmy for the first time. Car has 88K miles and still has some pad left. Rotors are clean with no deep grooves or signs of being over-heated. The old school in me says to put the rotors on a brake lathe and true them up. Others say its not neccessary.
Thanks for knowledgeable replys Gents.
NCGuy68 is offline   Reply With Quote
Old 09-27-2005, 03:15 PM   #2 (permalink)
View sanfelice's Photo Gallery
I have a 94 and was going to ask exactly that same question. When I had a Honda, they were very specific about not turning the rotors, but I did it anyway and it worked out fine.
sanfelice is offline   Reply With Quote
Old 09-27-2005, 03:30 PM   #3 (permalink)
View Gary_602Z's Photo Gallery
I would put the pads on with out doing anything to the rotors. Worst case is you might wear the new pads out a little quicker. By turning the rotors you risk getting brake pulsation from them being to thin. Next time you get ready to do brakes probably figure on replacing the rotors.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 09-27-2005, 03:35 PM   #4 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
as long as they are not too thin always have ur rotors turned, the new brakes will wear more evenly extending the life a bit and reliabilty of them. If the rotors are too thin to be turned or nearing that point, simply replace them, they are not that expensive
ag6286 is offline   Reply With Quote
Old 09-27-2005, 03:43 PM   #5 (permalink)
Moving Forward
View Cyorke's Photo Gallery
if you do not turn or replace them you can have more problems than normal with brake squeak also. You may also get some other noises and such. It is not going to be detremental to the operation of the brakes or anything like that jsut be forewarned about it.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 09-27-2005, 03:45 PM   #6 (permalink)
The rotors have never been turned - but I like the idea of knocking off a few thousands of a inch so the new pads seat well. Anyone know the minimum thickness allowable? I'am aware of too thin rotors and warping.
Thanks again Gents.
Old 09-27-2005, 03:50 PM   #7 (permalink)
Mr. DSM
Keep's Avatar
View Keep's Photo Gallery
Whenever I do my pads I get my rotors turned.
It lessens future problems with uneven wear patterns
Keep is offline   Reply With Quote
Old 09-27-2005, 03:52 PM   #8 (permalink)
Moving Forward
Minimum should be stamped on the inside of the rotor hub. if they have been on there that long you may need to scrape a little rust off to read it though.
Chris
Old 09-27-2005, 07:20 PM   #9 (permalink)
Thanks for the info Chris - I was thinking I should see the spec on the hub/rotor assembly.
