Help with lowering window when regulator out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2005, 08:24 PM   #1 (permalink)
View olddirtybaird's Photo Gallery
3rd Generation Help with lowering window when regulator out
Hi,
I have a 96' Camry and I just started on a mission to replace my power window regulator and motor, however I hit a problem. My window is up completely and every manual I've read has said to lower the window to remove the bolts fastening the window glass to the regulator guide, but my motor is totaly ko'ed and won't even go down at all . No guides have addressed this issue if your window is up and won't go down. I've tried force, but no luck, plus i'm worried that I might break something. I forget how old and brittle the plastic fasteners are on this car. So there is my problem. I would appreciate any advice. I'm tempted to just cut the wire on the regulator to hopefully let it drop below for access. Anyone think that's a good idea?
Thanks,
Stephen
olddirtybaird is offline   Reply With Quote
Old 09-27-2005, 09:52 PM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
If you are replacing the entire regulator and motor as an assembly Jsut cut the cable for the regulator. It is cable driven if I rememeber right. If it is cable driven then jsut cut the cable since you are going to replace it anyway. Once you cut the cable you should be able to lower the window as needed.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 09-27-2005, 10:40 PM   #3 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
take the motor off the new one and replace it with the old one and it should be an easier fix id think. BTW where are you getting your regulators from? i need for my entire passenger side
ekim55121 is offline   Reply With Quote
Old 09-27-2005, 10:43 PM   #4 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
eBay is your friend is you want power window regulators...
"live in the moment, forget the past and ignore the future"
Originally Posted by white3ch0c0late
Yes, Alex is the resident woman-problems guy here at TN... take his advice...
'95 i4 camry sedan -> wrecked june of 2006 by a girl who couldn't drive
'95 v6 camry coupe (dropped, rimmed, front end converted, tinted and debadged) -> current
95WhiteCamry is offline   Reply With Quote
Old 09-27-2005, 11:00 PM   #5 (permalink)
Moving Forward
SOme of them are made as one assembly and cannot be changed out seperately.
Chris
Old 09-27-2005, 11:17 PM   #6 (permalink)
My unit is all one piece. I got mine off of ebay for my driver's side for around $63 shipped, granted it is aftermarket, but I don't want to spend ~ 195 shipped for true toyota replacement parts. Ebay has a ton of aftermarket parts for the Toyota 92-96 Camry. Really convenient and reasonable.
Thanks for the replies. I think I'm just going to cut the wire and let it slide down since it's broken and I'll be replacing it anyways.
Stephen
Old 01-13-2006, 07:04 AM   #7 (permalink)
View BigChrisP's Photo Gallery
hey guys, i'm having a problem with my window too.... i wana replace it but not sure what to replace.. the window is up and it keeps slipping down, i try to roll it up but when i try the switch, nothing happens... it wont move but i do hear a little motor... should i replace both or just the regulator or will a new regualtor work with that old motor? thanks
1992 Toyota Camry I4
WRECKED
BigChrisP is offline   Reply With Quote
Old 01-13-2006, 10:03 AM   #8 (permalink)
Moving Forward
Normally the motor and regulator are all one piece. so youwill have to replace all of it. It isnt that hard to do.
Chris
Old 01-13-2006, 12:10 PM   #9 (permalink)
Dude wheres my Yaris ??
View darkus's Photo Gallery
Listen seriously just do it yerself
2007 Yaris for me (Red)
!!!!!!!! Yaris 4 life !!!!!!!!
darkus is offline   Reply With Quote
Old 01-13-2006, 02:43 PM   #10 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
Stephen
this is what anyone with a considerable window problem should do. the regulator setup is cheap as hell... quite a bargain as far as replacement parts generally go.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 01-13-2006, 06:27 PM   #11 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $911027
iTrader Score: 59 reviews
Maybe so! But I can't recommend the headlights!!...
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
