If the fuel pump stopped working while the car is running, would that cause a lean condition? What sorta problem would arise from having the fuel pump cut out while the engine is running, apart from the engine stalling of course .
Thanks
__________________ 1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
besides ur engine not being able to continue running or start again until replacement....none that i could even remotely think of that could cause damage to the feul system or any other
funny that u say that tho cuz my roomate just has his fuel pump go out on him on teh highway from virginia back to school here in WV....his GF ended up driving him back here and his car was left in VA......sux for him....he just picked it up this previous weekend and runs perfect again....minus the fact his transmission is ready to blow up... but thats an entire diff. story in itself
do u mean cause a lean condition for a bit previous to it actually stopping to work at all?
Yeah i mean, if one of the wires (say the power wire) is cut while the engine is idling, will the car just die immediately, or will it cause damage to the engine, as the amount of fuel leans out.
Good.
If you were to contemplate "disabling" the fuel pump, would it be best to cut the "relay trigger" wire, or cut the actual "fuel pump power" wire...and having that switched via a ... switch
Looking at the wiring diagrams, there are two wires to the pump, 1 in and 1 out. So it seems like cutting the relay signal would be a bit tricky, and it would be better to cut either one of the wires from the pump itself. Question is, do i cut the L-B(in) wire or the W-B(out) wire..hehe
If you cut into the main wires to the fuel pump you will need a higher rated switch to carry the current then if you splice into the relay side. Can I ask why you want to do this?
Gary
Don't worry about what other people think....as most of them don't!
what you should do is cut into the wire that triggers the fuel pump RELAY or even the EFI main relay. the one that is a low amp load. if you PM 88le, he has the electrical books for gen 2, i dont so i wouldnt know which wire you want.
Yep, it's an AC switch, but obviously can be used for DC aswell, it just has a higher rating.
Getting to the wires for the IGN or EFI Main relay are tricky, thats why I want to just splice this switch at the back. There are two wries to the fuel pump, so switching one of them would be the easiest route. What I also want to do is have a light to tell me the FP is OFF. Ill be switching it BEFORE i start the car, and won't be turning it off until the engine is stopped, but I askd the questions before, just in case it gets "flipped" while the motor is running.
that wouldnt cut power to the whole car though, it would just make it unable to be started with a key... it could still be started by jumping directly on the starter though...
