LOW and High Beam - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2005, 11:38 PM   #1 (permalink)
View Camrypaka's Photo Gallery
Gen5 LOW and High Beam
Dear All,
Anybody know how to make an adjustment on Low and high beam for CAMRY model 2006 which the low beam with HID Bulb ?
TQ
Camrypaka is offline   Reply With Quote
Old 09-29-2005, 12:20 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
I am not sure what you are asking. Are you trying to put HID or have you done that already or your car came with HID and you are trying to figure out how to aim them properly.
2007 Camry 2.4L 5M
Old 09-29-2005, 01:22 AM   #3 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
Maybe he's asking how to make the low beam as bright as the high beam?
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 09-29-2005, 02:27 AM   #4 (permalink)
Dear Sir,
Yes I try to fingure out how to aim the light properly
regard
Old 09-29-2005, 02:30 AM   #5 (permalink)
HID/Retrofit Expert
There are two screws behind the low and high beam... one moved the beamed horizontally, and one moves it vertically.
Old 09-29-2005, 02:32 AM   #6 (permalink)
Hi, do you know how to aim the low and high beam properly?
regard
Old 09-29-2005, 02:33 AM   #7 (permalink)
What is the best brand spring to lowered camry 2005 model
TQ
Old 09-29-2005, 02:35 AM   #8 (permalink)
Yes i notice that scew but I not very sure which screw for harizontal and vertical ,please advice
TQ
Old 09-29-2005, 02:40 AM   #9 (permalink)
The Other White Meat
terrastrife's Avatar
regard
its in your handbook. theres screws on the lamp housings.
TQ
none. buy what you prefer (comfort, height etc) FAQ.
terrastrife is offline   Reply With Quote
Old 09-29-2005, 10:10 AM   #10 (permalink)
HID/Retrofit Expert
TQ
Yeah, check your manual for that. I've never had to aim mine, I just know where it is in case I ever need to.
Old 09-29-2005, 10:37 AM   #11 (permalink)
Hawkeye-SE's Avatar
View Hawkeye-SE's Photo Gallery
TQ
There is only one adjuster. Vertical only, you cannot adjust the horizonal position.
http://www.danielsternlighting.com/tech/aim/aim.html
I doubt you will be able to get a good alignment because I assume you put in an HID kit, and the light output will be all over hell and creation.
Hawkeye-SE is offline   Reply With Quote
Old 09-29-2005, 03:01 PM   #12 (permalink)
LET'S GET ER' DUN
POOH71580's Avatar
View POOH71580's Photo Gallery
YOUR RIGHT HAWKEYE!
I have the 05 and there is only 1 screw on each assembly. It is either up or down. You will need a long phillips head screw driver to reach it through the guides.
I have the hid and have solved the problem about the little bit of glare people gripe about.
It is similar to what they call "eyelids" but different in its own unique way. It looks dang sexy too. NO MORE REASONS FOR PEOPLE TO COMPLAIN!!!!!!!
Pics will be posted soon.
2011 Tundra Sport
--Classic Chambered POWERSTICKS
--20x8.5 Rockstars (+10 offset)
--305/55/20 Nitto Terra Grapplers
--Ebay Halo/HID projectors
Cobragolf is my username on Tundratalk.net
POOH71580 is offline   Reply With Quote
Old 09-29-2005, 04:58 PM   #13 (permalink)
Hawkeye-SE's Avatar
An 8000k HID kit in halogen housings with a bandaid = I won't hold my breath.
Please take a picture from 20-25ft away from a wall of the beam pattern.
Old 10-01-2005, 11:22 PM   #14 (permalink)
Dear Hawkeye,
Thank your very much because help me to get the very usefull information
regard
Old 10-02-2005, 12:10 AM   #15 (permalink)
YOUR RIGHT HAWKEYE!
While you did fix the glare from HIDs, you probably did a proper retrofit. You probably are one of the few to do so. Many people do not, rather, they just put the bulbs in place of the halogen incandecent bulbs and expect them to work properly.
2007 Camry 2.4L 5M
