how to replace ac compresser - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-30-2005, 08:52 AM   #1 (permalink)
View 1991camryv6le's Photo Gallery
USA how to replace ac compresser
ac compresser in my camry went bad after i replaced drive belts can any one help me?
1991camryv6le is offline   Reply With Quote
Old 09-30-2005, 11:52 AM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
well first you are going to have to discharge the system of freon. SInce it is R12 you may have to convert to R134a while you are doig this if you ahvent already. Once you have discharged the sytem there are two hoses that attach to the compressor. You will remove those two hoses and any wires that are connected to it, remove the drive belt for the compressor, then there should be four bolts that hold it in place. They are screwed in from the front side if I rememerb right. Once you ahve those bolts off thenthe compressor should be ready for removal. You will also want to remove the alternator jsut to give you a little more room to work in there.
WHen you replace the compressor make sure you replace the o-rings on the hoses and the dryer for the A/C system.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 09-30-2005, 02:25 PM   #3 (permalink)
View Gary_602Z's Photo Gallery
Plus you will have to have it evacuated and recharged and hope you don't have any other leaks!
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 09-30-2005, 09:26 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
your better off letting a shop do it
Old 09-30-2005, 10:04 PM   #5 (permalink)
Oops forgot to ask what is it doing? Did it seize up or the compressor clutch go out or did it just quit working? Maybe you don't have to replace the compressor?
Gary
Old 10-01-2005, 08:17 AM   #6 (permalink)
View Leinad's Photo Gallery
Not good to discharge your AC in the atmosphere.
Let a shop do it, they'll vacumm it with a specialised tool and you will ahave a guarenteed job.
Very touchy jobs.....aluminium parts
Good luck.
Leinad is offline   Reply With Quote
Old 10-01-2005, 08:41 AM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
