my 3vz-fe is advanced quite a bit and no harm done that i notice, for awhile i had a big power problem, then i realized i forgot to change the distributor location. woops
. Ur engine will sound different, if it seems much louder after u do it...thats probably a bad thing as u most likely will not move when u step on the gas because of poor timing, jsut step it back a notch if it cant be fixed via distributor. Also i notice with my chng in timing, at an idle or when i take my foot off the pedal and the rpms steadily drop it has almost a back fire kind of sound, not loud, almost like a stutter periodically? if urs does the same,not to worry. make sure it doesnt do it a lot though. as for power gains...i def noticed a gain, however my engine is very unique and also a v-6, so u may or may not? try it out, the worst that will probably happen is less power or ur car just not starting at all, but thats easy to fix...
