Vented exhaust fumes dangerous? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2005, 11:26 AM   #1 (permalink)
View Ranger X's Photo Gallery
I have an emissions problem on my camry. Code P0446, which says there is a vent control malfunction with the EVAP system--could be a multitude of problems causing this code to come up, but long story short it vents exhaust vapors out of the gas cap instead of flitering them out. What I want to know is, can these fumes be dangerous? They're quite strong...not inside the car, but if I roll the windows down then it gets bad.
Ranger X is offline   Reply With Quote
Old 10-01-2005, 11:31 AM   #2 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
not sure about the code...bad o2 sensor?
umm...exhaust fumes bad....don't want to get carbon monoxide poisoning.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 10-01-2005, 11:51 AM   #3 (permalink)
Well, I know about CO poisoning. I was thinking more along the lines of combustion due to static electricity, or anything else. I do have a bad O2 sensor, but that's causing another code entirely to come up. According to the Haynes manual, P0446 is because of:
  • Open or Short in VSV circuit for EVAP
  • Problem with VSV for EVAP
  • Open or short in vapor pressure sensor circuit
  • Vapor pressure sensor circuit malfunction
  • Open or short in VSV circuit for vapor pressure circuit
  • Problem with vacuum hose (so it's not possible to recycle the vapors)
  • Charcoal canister malfunction
Could be any of those, maybe even a combination...regardless it's not something I want to mess with...I tried getting the darn canister off so I could check it, and I just gave up. Toyota couldn't have put it in a worse location.
