Unable to remove fuel filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2005, 08:39 PM   #1 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
Hi.
This sounds like a NOOB question.
I have removed 2 fuel filters, one for gen 3 and one for gen4 - both my cars.
I was helping my friend remove the fuel filter for a 99 solara and i am not able to undo the bottom bolt. I used a flair ranch, one to stabilize it and one to uninstall it but it did not budge.
Any suggestions.
Used WD40 also.
after 1.5 hours, i threw in the towel. I am going for round 2 tomorrow morning, suggestions are welcomed.
skewe is offline   Reply With Quote
Old 10-01-2005, 08:58 PM   #2 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
are you sure you're not trying to loosen the pseudo-nut that's built onto the filter? There's a bit that hexagonal shaped, but it doesn't turn.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 10-01-2005, 09:05 PM   #3 (permalink)
skewe's Avatar
no. not the nut built into the filter.
i am trying to remove the nut that goes under that nut you just mentioned.
using a flair ranch but i got 3 guys to take turns to try to loosen it..
did not budge.
i used a 9/16 flair ranch for that bottom nut.
Old 10-01-2005, 09:21 PM   #4 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
try ussing those plier that i think are called pressusure pliers. i used those to get it out on my cam.
V6LE_CAMRY is offline   Reply With Quote
Old 10-01-2005, 11:27 PM   #5 (permalink)
View Gary_602Z's Photo Gallery
Sounds like that the fuel line is corroded into the nut that screws into the filter! Take your WD-40 and thow it into the trash! (it is worthless). Go buy some PB Blaster and spray it down good then keep tapping on the fitting/filter with a hammer or something to set up a vibration to let the PB Blaster wick into it. Sray and tap for a while then using your line wrench take it off. You may have to use a piece of pipe or something to extend your leverage on the wrench. If it don't come you may have to replace the fuel line and fitting. Only use pressure pliers or vice grips as a last resort as they will ruin the nut.
Gary
Don't worry about what other people think....as most of them don't!
Gary_602Z is offline   Reply With Quote
Old 10-02-2005, 09:35 AM   #6 (permalink)
skewe's Avatar
i m not intending to use pliers yet as that might strip the bolt.
tried again this morning and it did not budge. might be returning the fuel filter
Old 10-02-2005, 12:09 PM   #7 (permalink)
View foompla's Photo Gallery
using the right size wrench might be a good start.
foompla is offline   Reply With Quote
Old 10-02-2005, 12:15 PM   #8 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
Use a blow torch No seriously, don't. You could try Liquid Wrench, its a penetrating spray for stuck bolts.
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 10-02-2005, 02:33 PM   #9 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Did you take out the air filter box? it gives you much more room to work in and get better leverage. Both my 98 and 00 came off with a sharp crack using one flare nut wrench on the bottom fitting and an open end wrench on the nut.
If you have a crows foot wrench and a long extension(s) you can see if you can put your ratchet on there.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 10-02-2005, 03:12 PM   #10 (permalink)
N/A bites
Tercel GTS's Avatar
I had to use 2 pipe wrenches(plumbing) on a chevy filter this week.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 10-02-2005, 03:16 PM   #11 (permalink)
The Cool Guy
Super Kaioken's Avatar
View Super Kaioken's Photo Gallery
when should you change the fuel filter? i have no clue where mine is.
-Custom 2.5in Cat-back Exhaust + Borla Muffler + Weapon R Dragon Intake + TRD Rear Sway Bar + TRD Springs + TRD Front Strut Brace
Super Kaioken is offline   Reply With Quote
Old 10-02-2005, 07:03 PM   #12 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
me thinks when you do the pcv valve.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 10-02-2005, 07:48 PM   #13 (permalink)
skewe's Avatar
Did that, unfortunately, that did not work.
onlyy problems is that it will not fit...as in the plumbing pipes as the space is too tight.
Yes, I removed the filter box.
I have removed it on a 93 and 2000 w/o any problems. flare wrench used both occassions but this time, it will budge.
Haynes manual suggest, 24 months or 15k miles.
i have never done it for my gen 3 till 168k.
Old 10-03-2005, 01:35 PM   #14 (permalink)
The Cool Guy
are you serious .......15K miles? i should really change mine then. i'm up to about 49K. where is this fuel filter at? got pictures?
Old 10-03-2005, 02:09 PM   #15 (permalink)
Geez a quick search shows to look under the airbox! Worse comes to worse just follow the fuel lines back towards the fuel tank! Maybe a manual would be of some help also.
Gary
