Originally Posted by Luckynumber5
No, the supra Ct-26 is different, and the 3sgte manifold will not bolt up to a 5sfe.
WRONG.
The 3SGTE manifold will bolt up. This has been common knowledge for years...
Where the hell did you hear that?
The Supra CT26 IS different, but if you swap the exhaust housing for a twin entry CT26 [MR2/Alltrac] it will bolt up. You just have to rotate the compressor housing a bit and do a custom mount for the wg actuator.
It has a larger compressor wheel than the 4 cyl one, too, so it's an upgrade.
