Originally Posted by Tercel GTS
Pressure isn't your problem as it's leaking while shut off. My dollar says you have a bad injector or trash stuck in it.
I'll put a dollar on trash in the injectors as well do you have the fuel system flushed or just the injectors.. By that i mean did you pull the injectors when you cleaned them or did you flush the system by hooking a pressure cleaner to the fuel rail?? If you pressurized the rail i bet some trash got knocked lose and is holding an injector open..
