wheel shaking - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 10-22-2006, 06:12 PM   #1 (permalink)
View dillard5155's Photo Gallery
wheel shaking
when i was driving down the freeway yesterday, after i had put on a spare tire on my 1992 toyota camry le, i began to have a very bad shaking in my car. it got so bad that i could barely control the car on the regular street. the steering wheel was shaking very badly. i checked the spare tire and everything was put on the way it needed to be and nothing was visibly wrong. Anyone know what could be wrong, and is it an easy fix?
dillard5155 is offline   Reply With Quote
Old 10-23-2006, 06:38 PM   #2 (permalink)
View kyle@tirerack's Photo Gallery
A vibration can be difficult to pin point but the fact that you just put the spare on should be helpful. The easiest thing may be to have your original tire repaired/replaced and have the temporary tire checked in the process. The link below is a chart to help work through the vibration if no problems with the spare can be identified. vibration chart
kyle@tirerack is offline   Reply With Quote
Old 12-20-2006, 04:11 PM   #3 (permalink)
andysautosport.com
View gyrex's Photo Gallery
maybe it could an unbalanced spare tire?
gyrex is offline   Reply With Quote
Old 05-16-2008, 01:23 AM   #4 (permalink)
KathyLue's Avatar
View KathyLue's Photo Gallery
Thanks Kyle. I printed your chart and will go outside and check those suggestions.
\\k//
KathyLue is offline   Reply With Quote
Old 05-16-2008, 01:24 AM   #5 (permalink)
KathyLue's Avatar
Thanx, I will check under the truck when the sun comes up.
\\k//
Old 05-17-2008, 11:54 PM   #6 (permalink)
View thoughthard's Photo Gallery
Did you put the spare on one of the back positions?
Do you have alloy wheels, and used the alloy wheel lugnuts on the steel spare wheel?
*FYI: Beer was involved in this post, if they make no sense*
thoughthard is offline   Reply With Quote
Old 05-18-2008, 03:54 AM   #7 (permalink)
rty
Gameroom cash: $297366
View rty's Photo Gallery
That would be my guess.
rty is offline   Reply With Quote
Old 05-18-2008, 07:15 AM   #8 (permalink)
KathyLue's Avatar
No spare on truck. Its a big pain in the•••. My tires are good and i can geet hte spare brought out...
\\k//
Old 05-18-2008, 07:16 AM   #9 (permalink)
KathyLue's Avatar
I will get tires balanced and if that doesn't work... I already had an alignment.
\\k//
Old 06-02-2008, 04:49 PM   #10 (permalink)
DjiNN's Avatar
View DjiNN's Photo Gallery
Well what caused my car to shake was a bent rim. SO now i have to buy a new stock steelie .. or go with some aftermarket rims.
Subaru Impreza 2.5i Premium Satin White
DjiNN is offline   Reply With Quote
Steering Wheel Noise Trd_Thunder 2nd Generation (2005+) 9 02-21-2007 01:05 PM
Dealer told me my steering wheel is supposed to be crooked! da5176 1st Generation (2001–2007) 8 06-13-2006 10:38 PM
Gen 5 Wheel problem steveeble 5th & 6th Generation (2002-2006 & 2007-2011) 0 05-07-2006 02:12 PM
repair steering wheel - wear on spokes celicaGTswan85 General Discussion 4 04-07-2006 05:45 PM
Front Wheel Drive To Rear Wheel Drive theman33b Camry & Solara Lounge 15 12-15-2005 04:03 AM
