Tire Pressure Monitoring Systems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Closed Thread
Old 11-07-2006, 05:27 PM   #1 (permalink)
View kyle@tirerack's Photo Gallery
Toyota/Scion
Tire pressure monitoring systems (TPMS) are now impossible to run from when buying a new vehicle. Every new vehicle made for sale in the USA has a direct TPM system as standard equipment. There are several exceptions though: the vehicle must have only four wheels (so no dual-wheeled trucks or motorcycles), and the GVWR must be less than 10,000lbs.
We carry sensors for all Toyota’s and Scion’s up to the 2008 model year.
The basics of the direct TPMS is that it uses a sensor in the wheel/tire to wirelessly relay pressure back to the driver on some sort of display. Some vehicles have a digital info screen that will show all four tire pressures (five pressures if spare has sensor) all the time. While others might just flash a low-tire-pressure light on the dash. There are also two different styles of sensors for this system: a valve sensor and a strap/band sensor. Only valve sensors are used by the direct system-equipped Toyota’s and Scion’s, although if you bought an aftermarket SmarTire TPM system, those use the sensors held on by a strap around the barrel of the wheel.
Several older Toyota’s and Scion’s use an indirect system and it will not affect the choice of switching aftermarket wheels or tires. The system runs off of the ABS/wheel-speed sensors which “count” the number of revolutions of each tire. If the right-front tire is low (25psi) it will spin faster than the left-front tire (35psi), so the ABS system will recognize this change and alert the driver with a flashing light near the gauge cluster and possibly a loud chime.
Toyota and Scion currently use several sensors from two companies: Pacific and TRW. The size of the sensor shouldn’t be a problem for many wheels, but if the valve hole is in the middle of the wheel’s barrel, then obviously the sensor will not fit properly. The wheel industries are aware of the valve sensors and are rushing to get most of their wheels TPMS-compatible. If you have any questions about the TPMS-fitment on a wheel that The Tire Rack sells, I can look up the wheel and confirm if it will work with your vehicle.
kyle@tirerack is offline
Closed Thread
Low Tire Pressure Indicator Reset FYI Wizrd23 5th & 6th Generation (2002-2006 & 2007-2011) 5 04-29-2011 10:43 AM
Tire Pressure, How much do you have? Chazmanian 2nd Generation (2005+) 28 12-07-2006 12:49 PM
Tire pressure light fslaugts 2nd Generation (2005+) 20 11-04-2006 08:49 PM
Tire pressure? alexrobbins 1st Generation (2005-2010) 1 01-14-2006 11:48 AM
Tire Pressure Mr.Incognito Hardcore Tech and Competition 18 07-14-2002 06:31 PM
