Wider Wheels & Air Pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 11-15-2006, 02:40 AM   #1 (permalink)
Tom 2000's Avatar
Gameroom cash: $189850
View Tom 2000's Photo Gallery
I have 205/60R16 tires mounted on 16 X 7 aftermarket alloy wheels on my 2000 Camry LE. I drove about 45K miles on the tires and the tires had worn. Specifically, the shoulders wore out faster than the center of the tread, which still had some tread left.
I have always made sure that the tires were inflated to 30 PSI, which is what Toyota recommended (based on stock 205/65R15 tires).
As my aftermarket wheels are wider than stock, would my tires have worn more evenly if i had increased the air pressure a bit?
I want to make sure the next set of tires will last and wear evenly.
Thanks,
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 11-15-2006, 11:14 AM   #2 (permalink)
View kyle@tirerack's Photo Gallery
Tom,
I show the placard for the 2000 LE as 32psi on the 205 65 15. This tire will carry 1,334 lbs at 32psi. The 205 60 16 would carry the same load at 34 psi. I would recommend running in the 32-34 psi range on the next set of tires. Feel free to contact me directly to discuss the details.
kyle@tirerack is offline   Reply With Quote
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 11:43 AM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
Tire Pressure Monitoring Systems kyle@tirerack The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 11-07-2006 05:27 PM
