tire size for 19" sc400 - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 11-24-2006, 02:35 PM   #1 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
SC400
19x8.5 in front
19x9.5 in rear
+35 on both
I want the widest tires possible 265+ in rear, what do you recommend to keep the proper speedometer?
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 11-24-2006, 05:48 PM   #2 (permalink)
View NYLexSC's Photo Gallery
Are you lowered at all? what are the offsets on the wheels?
You will probably have to roll or maybe even shave your fenders front + rear, but the tire sizes you can run are:
265/30/19
275/30/19
NYLexSC is offline   Reply With Quote
Old 11-24-2006, 05:50 PM   #3 (permalink)
View kyle@tirerack's Photo Gallery
A 275 30 would fit and be within a few tenths of an inch in overall diameter from the stock tire.
Didn't realize already answered above by NYLex.....sorry for copy.
kyle@tirerack is offline   Reply With Quote
Old 11-25-2006, 09:31 AM   #4 (permalink)
Lex Zues!
RedPhoenix's Avatar
265 will fit on the front? it will be lowered
Sold ^
Old 11-25-2006, 07:11 PM   #5 (permalink)
depending on the offset on the wheels, maybe. But probably NOT without some fender modification. Most likely a roll would be sufficient if your offset is going to be around the +40 region. I know a 245 will fit well up front, but anything higher and you will likely need to roll.
Old 11-26-2006, 01:56 AM   #6 (permalink)
Lex Zues!
RedPhoenix's Avatar
245 would be fine for me. enough to keep traction when needed
Sold ^
maximum size of tire for a 16 inch rim? Matus1 89-95 Toyota Pickup/Hilux 2 07-17-2009 06:16 PM
tire size? andriod8000 1st Generation (1995.5–2004) 1 03-01-2006 09:34 PM
Tire size comparison calculators HoustonHokie 2nd Generation (2005+) 4 02-24-2006 02:22 AM
Tire Size For 2005 Dbl/cab 3 Inch Lift warehouseboy 2nd Generation (2005+) 13 03-29-2005 02:36 PM
Stock ae92 Sedan tire size Phreshnphunky Archived Corolla threads 3 01-29-2004 09:37 AM
