SS BrakeLines/H4s - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Nation Forums > The Discount Tire Direct Tire, Wheel, Brake & Suspension
The Discount Tire Direct Tire, Wheel, Brake & Suspension Tire, Wheel, Brake & Suspension Forum sponsored by Discount Tire Direct
Old 12-23-2006, 11:50 AM   #1 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
4th Generation SS BrakeLines/H4s
Hey!
I just got some G-Stop SS lines from tire rack. excited to install them. Do they need to be broken in or anything?
Also i got Yokohama H4s tires all around, and was wondering is it bad to mix tire pressures?
for example. My fronts are 38psi my rears are 35 psi. Reason for me doing this is because the front my car is like a whale while the back is like a penguin. The front tires look flatish around 35 or less, so i decided to pump them up.
on the sidewall the tires read max 44psi at some pounds...(i forgot right now). I'm assuming it should be OK?
Thanks and Happy Holidays!
nodrogkam is offline   Reply With Quote
Old 12-23-2006, 09:24 PM   #2 (permalink)
Embrace the Suck
Edmo83's Avatar
iTrader Score: 8 reviews
View Edmo83's Photo Gallery
i got the same tires, i keep them at 38 all around, i doubt youd have any problems with mixing them dude.
love them tires btw!! they are amazing in the rain, and grip like crazy! only gripe is they arent as quiet as the yoko dB's were, these were QUIET!
92 SC300 Garnet Red 5-speed 119k
01 Camry LE V6 Sailfin Blue 95K miles
Edmo83 is offline   Reply With Quote
Old 12-26-2006, 10:19 AM   #3 (permalink)
View kyle@tirerack's Photo Gallery
No need to break in the lines. Just install and bleed the system and you will be good to go.
kyle@tirerack is offline   Reply With Quote
Old 12-27-2006, 01:54 AM   #4 (permalink)
nodrogkam's Avatar
thanks all!
yeah the yokos are great! i just had them out in the rain and wow...much better than any other tire ive ever had. under max braking the ABS barely went off!
yes they aren't as quiet as a lot of other tires out there, nor do they feel as smooth...but they're sticky and real good for the price.
dB's are on another level man!
Old 12-27-2006, 10:37 PM   #5 (permalink)
nodrogkam's Avatar
sigh i can't get the bolt that attaches the line onto the strut...
i broke some tools in the process but its a miracle that the nut its okay.
do i need to use both a wrench and a ratchet? i noticed there was a on the back of the strut, so i guess if i twist in opposite directions it would get it loose?
haha i really dont want to break any more tools! thanks for any advice!
Old 12-27-2006, 10:56 PM   #6 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $355745
View atobe's Photo Gallery
you need a flare wrench for these type of nuts don't want to strip them
Old 12-27-2006, 11:20 PM   #7 (permalink)
nodrogkam's Avatar
amazingly even after damaging bits and what not the bolts havent been stripped...
guess im getting better at keeping the bit on the bolt but it just wont budge.
is this the type of wrench you're talking about?
what difference would that make vs. just using a ratchet/crescent?
Goodridge SS Brake line install tip Poman Camry & Solara Lounge 0 06-03-2006 10:56 PM
Cobalt SS - RSX comparo dsmnick General Discussion 84 09-15-2005 01:33 PM
Technafit SS Brake Lines: impressions, problems brink Hardcore Tech and Competition 5 04-28-2004 02:54 PM
SS Clutch Lines allblackalltrac Hardcore Tech and Competition 0 10-15-2003 03:34 PM
There is NO Replacement for Displacement!!!!! goodcookiedrift Off Topic 16 11-29-2002 03:15 PM
